I have no oil pressure on my
I have no oil pressure on my starbord engine.
I have determined the guage & sending units are functioning properly. the engine is not using any oil & the oil is clean. The engine starts & runs without much clatter. My guess it is the oil pump is not working as i noticed before it quit it only had about 20 lbs pressure.
Removing the engine is out of the question. I do have room to drop the cast iron oil pan/ bottom of the motor down 5-8 inches I believe i can remove it. My real concern is will re installing the pan with the new 4-piece gasket be an imposssible task? Or is there something I haven't cosidered that will make this impossible.
Could no Oil pressure be a result of something other than a bad pump?
any suggestions
thanks kman
any suggestions
thanks kman
