" Trying to start my Model K t
" Trying to start my Model K that "used to run great" 4 years ago. Compression check showed zero compression in cylinders 1, 3, 5 and 6 and only 30 psi in 2 & 4. Sprayed liquid wrench to free any stuck valves and looses rings. Then tried mystery oil. Still no compression.
Before I pull the head, I have to ask, what can make a "good" engine go to zero compression in 4 years? Turned it over myself and squirted oil in the cylinders every fall. "
