K
Kent Bloomquist
Guest
" When the throttle is in wide
" When the throttle is in wide open position I get a seeming slight miss, so I back it off just a hair and it clears up and runs well. Not a problem at full RPM but under load of more than a couple people, it can not get up enough RPM to clear out. Seems to cut out on the upper cylinder. Ran smooth with top wire disconnected, intermittent miss with bottom disconnected at full throttle. Ideas to check?? "
