G
Gil Murray
Guest
Compression checks normal and
Compression checks normal and the carbs have been gone through by two dealers and an individual. Jets have been replaced to factory specs and are new. The engine still runs rough in idle.It is fine at higher speeds. It does take awhile to get to full power but I have a heavy boat. It is stronger at idle in the shop when hooked up to a hose than it is in the water. It does not stall out. Could you help?
