King Cobra wonbt shift into neutral while engine is running
marcell
I recently bought a 89 22 Don
I recently bought a 89 22 Donzi Classic w/ 460 Ford-King Cobra Combo. Once you engage the outdrive in fwd it will not shift back into neutral without turning off the engine. Please Help?
" Marcell,
Your shift interru
" Marcell,
Your shift interrupter switch is not working. This switch momentarily kills half of your ignition system to "unload" your clutch dog and make it possible to shift out of gear. It consists of two cherry switches. One engages the system, the other overrides it. These switches are connected to an ignition module. You will need a good service manual if you are going to fix it your self. If you choose to take it to a dealer, at least you aren't going in blind. Good luck. "
