E
Eric Ohnemus
Guest
" Joe,
You have been very
" Joe,
You have been very helpful with the last two questions I have posted, first was the problem with no fire, I replaced the Amplifier and it now has fire. Next was the problem that it would not go but 2-5Mph at full throttle, you said to clean the carbs. I rebuilt the carbs and now it planes out and runs in the 30s. Now my newest problem is that it will not start again. I turn the key and the starter ingages and turns the engine about a half a turn. then it stops like the battery is dead, put in new battery and same thing. If i take out all of the spark plugs and turn the egnition the starter ingages and roles over and over just fine. If I put just one plug in with no wire connected at all and try to start it the starter ingages and turns over a couple of times then stops. Thanks again for all the help and I look forward to your help with this latest problem, hopefully it will be the last for awhile.
Thanks,
Eric "
You have been very
" Joe,
Thanks,
Eric "
