Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 2 of 2
  1. #1
    steve35's Avatar
    steve35 Guest
    Default Been having a problem with th
    Been having a problem with this dam engine She has heaps of spark Jumps 7/16 compression is great 110 on 2 all and 106 on the other carbs are good and clean reed valves are good seems to run on 2 and then seems to thump every now and again.
    I was wondering although it has good compression could the ring s on one of the cylinders be stuffed so there is no vaccum in one pot I have looked into the intake side and noted that one piston has 2 rings on the piston and the other 2 pistons have three
    Your thoughts are appriciated
  2. #2
    Join Date
    May 2001
    Posts
    1,678
    Default " Steve, Merc made pistons
    " Steve,
    Merc made pistons with two and three rings. Functionally, they are the same, but I think you are better off with the three ring pistons. Someone rebuilt that powerhead.
    Even though the compression is good, a piston may still need rings. If the rings are worn you can have compression, but as you stated, the vacuum may be low. When this is the case it can usually be diagnosed by turning the flywheel clockwise by hand and feeling the compression in each cylinder. If the rings are worn you will probably feel very little resistance in that cylinder when you do this.
    Tony "
Similar Threads
  1. 50 Merc Blue Band, trouble after not opening fuel tank valve.
    By alexbaum in forum Mercury Mariner Outboard Forum
    Last Post: 09-04-2010, 12:49 AM
  2. mercury blue band
    By Karlos22 in forum Mercury Mariner Outboard Forum
    Last Post: 07-05-2010, 12:11 AM
  3. Blue band 80 drive problem
    By ballcock in forum Mercury Mariner Outboard Archive
    Last Post: 05-05-2008, 12:44 PM
  4. Mercury 75HP Blue Band need HELP
    By tkearney in forum Mercury Mariner Outboard Archive
    Last Post: 03-16-2006, 05:29 PM
  5. Trouble starting blue band merc 70hp
    By justin maslen in forum Mercury Mariner Outboard Archive
    Last Post: 10-21-2003, 05:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
