Results 1 to 7 of 7
  1. #1
    Craig Jones's Avatar
    Craig Jones Guest
    Default " Cannot locate any tech info.
    " Cannot locate any tech info. Need to know if automotive heads, and intake are compatible..?? If not, I need some kind of reference to original heads & intake. Pic, literature, etc... Thank you... Craig "
  2. #2
    PeterBruun's Avatar
    PeterBruun Guest
    Default " Hi Craig! First, remember t
    " Hi Craig!
    First, remember that 272 and 292 engines belong to the old Y-block family. The 289/302 engines belong to the more modern small block family. Parts between these families DO not mix!
    I don't think, a marine or auto intake will differ at least not for the 289/302:s. With the heads issue I'm not sure.
    Peter "
  3. #3
    croozertoo's Avatar
    croozertoo Guest
    Default "I'm a little late with th
    "I'm a little late with this reply, but I've worked with the Interceptor Y-blocks a bit. These are good engines, but the Interceptor conversion of the 50's and 60's used a "flat" intake manifold and one or two side draft carbs. The carbs are finicky and tend to leak, creating a fire hazard.
    If you have enough vertical clearance and originality is not a concern, I'd recommend using an automotive style intake and a modern marine four-barrel carb. Hemmings would be a good source for a Y-block intake. I believe the Thunderbird four-barrel versions were compatible with an AFB type carb.
    [img][/img]"
  4. #4
    Join Date
    Sep 2008
    Location
    Cadillac, Michigan, USA
    Posts
    4
    Default "I, too have a 59 Century with
    "I, too have a 59 Century with a 170 Horse Interceptor (272 CI) with the twin side draft Carter carbs. I would like to convert this to a downdraft intake with either a 2 barrel or 4 barrel carb. Can anyone advise if their was a marine or auto intake in a 2 barrel version? If so, where could I find a used one? If not, where could I find a used 4 barrel version and at what approximate cost?"
  5. #5
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    14,512
    Default "A marine Holley two barrel co
    "A marine Holley two barrel could be adapted easily. The old Ford 2 barrel even looked like a Holley--Henry Ford and the Holley brothers came up together.
    The 272/ 292/ 312 series of engines (what was it with that last digit always being a '2'?) were not good engines back then, but modern oils would make them a real winner.
    Jeff"
  6. #6
    Join Date
    Jun 2007
    Location
    Harwood, Md, USA
    Posts
    28
    Default Does anyone know how the water
    Does anyone know how the water system on the inteceptor connects to the down draft manifold so that water feeds both exhaust manifolds and flows back to the raw water pump?
    thnx in Advance
    Ray Glenn
  7. #7
    sam Ivanitz's Avatar
    sam Ivanitz Guest
Similar Threads
  1. Ford Interceptor marine engine
    By Glenn Copeland in forum Ford Interceptor Marine Engine Forum
    Last Post: 08-10-2013, 11:47 PM
  2. Need Help on a 302 marine ford interceptor motor
    By james3119 in forum Ford Interceptor Marine Engine Forum
    Last Post: 07-21-2009, 01:36 AM
  3. 390 Ford Interceptor
    By Dave Sarlund in forum Ford Interceptor Marine Engine Forum
    Last Post: 10-27-2006, 04:39 PM
  4. Ford Interceptor
    By Ron Grabloski in forum Ford Interceptor Marine Engine Forum
    Last Post: 08-13-2002, 09:33 PM
  5. b57 Ford Interceptor
    By sampolito in forum Archive 2002-2006
    Last Post: 11-18-2000, 11:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
