Click for Bukh manuals!
Results 1 to 7 of 7
Thread: Bukh DV engine
    Tommy Petri's Avatar
    Tommy Petri Guest
    Default "Hello, I have bought a new B
    I have bought a new BUKH DV7 marine diesel. Itís based on a Farymann 18W engine.
    Iím really confused about the lack of a proper air filter Ė itís just an empty can on the air intake.
    The can has a strainer with big holes (sq. mm) for air inlet. Anyone knowing about it ?
    I have never heard of marine engines without air filter. Experience of Bukh DV7?
    Bryan Ahern's Avatar
    Bryan Ahern Guest
    Default "My Bukh DV8 has no air filter
    "My Bukh DV8 has no air filter. It is 23yrs old, starts easily and runs nicely."
    May 2007
    Belmont, NSW, Australia
    Default My Bukh also has a strainer ty
    My Bukh also has a strainer type air filter. Good for keeping out nuts and bolts but not dirt and grit. I intend to replace it with a car air filter. Housing and filter about $30 from the auto shop.
    Dec 2005
    Vancouver , British Columbia , Canada
    Default "Many of the older marine engi
    "Many of the older marine engines had this can, some just had an intake pipe. This can is a silencer. That is it cuts the noise of the air rushing in. Suprisingly it does a good job. If you think about it, your engine if working on the water and not in some drought ridden wheat field or construction pit where dust and dirt is a factor. If you fit an after market air filter system, make sure you have not added any air restriction."
    Apr 2008
    Sant Pere Pescador, Girona, Spain
    Default My dear old Bertie the Bukh &#
    My dear old Bertie the Bukh (DV20M) has suffered a minor upset. Does anyone know where I can find the Torque loading figures for the Cylinder Head and the inlet and exhaust valve clearances.
  6. #6
    Tom D's Avatar
    Tom D Guest
    Default "Tim, The Torques are; Cylin
    The Torques are;
    Cylinder Head 9.5-10.5 KGM (68.7-75.9 FT.LBF you will probably require a special tool which I think is a 19mm crawfoot wrench to tighten the head
    Valve clearances;
    Inlet 0.25mm (0.01 inch)
    Exhaust 0.30mm (0.012 inch"
  7. #7
    Sep 2008
    Vancouver, BC, Canada
    Default "I have recently acquired a 40
    "I have recently acquired a 40 X Yacht with a BuKh diesel.
    I'm told it has a 6 horsepower Bukh diesel and it pushes the boat along quite nicely. It has a sail drive and I'm thinking I should replace the zinc anodes. Does anyone have any information on the typical diameter of the prop shaft for this Bukh, or most Bukh diesels with sail drive.
    And if you know any tricks for changing the zinc anodes that would be appreciated as well..
    Gerard F."
  1. Replies: 11
    Last Post: 02-13-2011, 05:13 AM
  2. Bukh DV 18
    By nautiko in forum Bukh
    Last Post: 12-08-2008, 03:26 PM
  3. Bukh DV 24 ME
    By gwb in forum Bukh
    Last Post: 01-02-2008, 12:17 PM
  4. Bukh parts
    By andrew in forum Bukh
    Last Post: 06-13-2006, 07:49 AM
  5. Bukh engine
    By onokaya in forum Bukh
    Last Post: 03-27-2004, 09:57 AM
