"I JUST BOUGHT A 04 GLASTRON S
"I JUST BOUGHT A 04 GLASTRON SX195 WITH A 5.0 LITER/ALPHA DRIVE. THE BOOK LISTS DIFFERENT GREASE FOR THE GIMBAL BEARING, U-JOINTS, COUPLER,... CAN I USE A GOOD MARINE GREASE FOR ALL OR DO I NEED TO BUY 5 GREASE GUNS AND GREASE. IS MERC DOING A SALES JOB OR WHAT?
ALSO, THE BOOK SAYS "YOUR POWER PACKAGE IS EQUIPPED WITH A SEALED ENGINE COUPLE AND PERM-A-LUBE U-JOINTS. THE SEALED COUPLER CAN BE LUBRICATED WITHOUT REMOVING THE STERNDRIVE UNIT." IF IT IS SEALED, WHY GREASE IT AT ALL OR CAN IT BE GREASED? DOES ANYONE KNOW HOW MANY GREASE FITTINGS THERE ARE TO BE GREASED? DO ANY OF THESE GET GREASE FROM INSIDE THE ENGINE COMPARTMENT? ALL I SEE IS ONE FITTING ON THE TRANSOM ASSEMBLY TO GREASE THE GIMBALL BEARING. HELP!!!!!!!! THANK YOU IN ADVANCE-VERY MUCH !!!"
