Results 1 to 4 of 4
  1. #1
    Default to change a water pump in a 19
    to change a water pump in a 1994 150 saltwater series yamaha going by the manuel pretty much as simple as it reads or there and tricks good or bad. thanks for any advice.
  2. #2
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default "yes there are a ton of tricks
    try here
    http://www.thehulltruth.com/forums/t...9&posts=45"
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  3. #3
    Gene Howell's Avatar
    Gene Howell Guest
    Default I am trying to change a water
    I am trying to change a water pump on a 92 200hp yamaha. I took the 6 bolts that hold the lower unit out. Took the zinc trim tab and the bolt underneath out. Also left the motor in gear. It is not budging. The water pump was replaced 2 years ago and would not think it is corroded on. What the heck do I do.
  4. #4
    Join Date
    Sep 2006
    Location
    Posts
    8,649
    Default not in gear is what u want
Similar Threads
  1. Changing Water pump
    By carlnap in forum Mercruiser Sterndrive Archive
    Last Post: 01-27-2008, 06:35 AM
  2. 1968 Evinrude 65 V4 Water Pump Changing
    By kevinperry in forum Johnson Evinrude Outboard Archive
    Last Post: 07-19-2007, 03:38 PM
  3. Changing water pump impellers
    By Boca Rick in forum Mercruiser Sterndrive Archive
    Last Post: 05-16-2007, 12:30 AM
  4. Changing Water Pump
    Last Post: 03-13-2007, 07:01 AM
  5. Merc 98 water pump changing
    By Jeremey in forum Mercury Mariner Outboard Archive
    Last Post: 01-10-2004, 02:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
