Results 1 to 5 of 5
  1. #1
    Default " Motor will not start, checke
    " Motor will not start, checked for spark and do not have spark, there are no specs in the tech manual that i have, to test the coil and distributor, unplugged the shift interrupt switch, still no spark, Can someone give me the specs on the items listed or if someone has experienced the same problem, let me know what they replaced to get spark,
    have 12 volts going to the coil, 9 with with the resistor wire, in place, "
  2. #2
    smartyjr's Avatar
    smartyjr Guest
    Default "Hello Mike. If you're sti
    "Hello Mike. If you're still having problems with no spark contact me at, [email protected]"
  3. #3
    Tom Love's Avatar
    Tom Love Guest
    Default "I have '88 OMC 5L 305, no
    "I have '88 OMC 5L 305, no spark at all, chranks over graet! points look good, pulled coil plug wire at dist., no ark at all, pulled plugs, look older but seem ok. Has not been started for 5+ years and has been rained on during the last winter do to covers being stolen during storage!!! Ciol is rusty, new rebuild 2 berrel rochester, has fuel. At one point seemed to sputter once or twice for 1/2 second, but sence then, nothing. Jumped pos. side of coil to bat., nothing! I have some skills on engine troubleshooting, but nothing with marine engines and there engine wiring, ie. controllers, mods. etc. tonight I will try to disconnect all but basic power to starter solinod & ciol to see if i can get anything at all. Will stop and get new ciol, points, cond. befor trying, asssuming it doen't work, any one have any ideas???"
  4. #4
    Join Date
    Jul 2006
    Location
    Keswick, Ontario, Canada
    Posts
    1,847
    Default "I would really look over the
    "I would really look over the points good, can you see if they are opening and closing while it's cranking? If so is there any spark there, might just need a good cleaning.
    ...ps Tom...you should really start a new post of your own even thought the symptoms are similar rather than jump into an old post."
  5. #5
    Tom Love's Avatar
    Tom Love Guest
    Default "Sorry Bob, This was my first
    "Sorry Bob, This was my first post anywhere, anytime. I will try to start a new Post. kind of a rookie on computer. Thank You"
Similar Threads
  1. 1991 5.7 Cobra Starter replacement
    By BuilderBob in forum OMC Sterndrive and Inboard Forum
    Last Post: 12-29-2010, 01:31 PM
  2. Help 1991 30 OMC Cobra
    By reganhopkins in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-12-2009, 04:53 PM
  3. 1991 OMC Cobra Horsepower
    By marbletop in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-03-2007, 03:22 AM
  4. 1991 OMC 43l with Cobra Drive
    By peconicbay in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-22-2007, 03:40 PM
  5. 1991 Cobra 30 ESA problems
    By Mark Chisholm in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-21-2007, 06:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
