"started on muff engine runs o
"started on muff engine runs ok at half throttle on cold start,but when throttle is backed off engine misses and dies.carbs have been cleaned but no difference.i did notice that when i pulled number 3 cylinder plug wire off engine ran the same as if i didnt take plug wire off.150 lbs compression on all 3 cylinders.any suggestions as to what i should check.thanks"
