"2001 21' chriscraft with
"2001 21' chriscraft with a 5.7 Volvo in her. Went to start the motor, and sheered both starter bolts off in the block. After a few hours of very odd angles, was able to remove the remaining bolts out of the block. Talked to a mechanic who informed me the only way this could happen, is water filling a piston. So began winterizing the motor, and when pulling the 2nd to last plug out, water came out. First suggestion was to pull the Exhaust Manifold, which when i did, found that the gasket on both the riser and the one on the block were both in bad shape. Was able to find a new exhaust manidfold on e-bay which i tested with gas to make sure it was ok, and i plan to put it back together this weekend. If replacing gaskets does not solve the problem, am i looking at a possible head gasket or bad block? What would be my next step of troubleshooting? The exhaust manifold looked in good condition, but since i got a new one, i am going to go ahead and install the new one. Anyone looking for a used manifold, I'll have it for sale, just e-mail me back."
