1989 175 XP VRO Fuel Pump Replacement
dfmatt
"Can a VRO fuel pump be replac
"Can a VRO fuel pump be replaced with a regular fuel pump? I have had the oil tank removed, and the VRO oil line plugged, on the last engine rebuild per the rebuilder. I have had several VRO pumps go out since at $300.00 a pop. This is on a 1989 XP 175 Looking for a better way to get up and running again. Sorry if this is a second post. I had trouble on the first one.
Thanks"
"Denny,
The manufacturer ma
"Denny,
The manufacturer makes a replacement fuel pump which looks like a VRO, but does not blend oil. It attatches to the same bracket and costs a lot less.
Tony"
