Remove oil injection system
M
M.W.Stringer
Guest
How do you remove the oiling
How do you remove the oiling system on 1999 200 h.p.efi Mercury?
" The whole system? what for?
" The whole system? what for? the tank is easy three bolts with 10ml heads and one hose going in and one going out, the oil pump is on the port side of the engine with one hose going in and one out, and two bolts with 8ml heads. If you want to get the oil drive out you have to pull the whole power head apart. "
