lbrannon2007
"My exchanger cover seat that
"My exchanger cover seat that houses the plastic spacers is corroded and does not seal properly, and links raw water into the bilge. I want to replace the cover, and I am realistic enough to know that I will probaly have to buy a used exchanger just to get the part a I need. I also have idling problems. Prior to my exchanger problems, my engine would not idle at 900rpm (per Selco) and would surge uncontrollably when started. Mind you, I have to pump the throttle just to start the thing, but once started the RPMs would race up to 3000rpm + which required me to throttle down quickly, not to idle, but just enough to keep the engine from red lining, while contuning to race up and down. Help!! PS I am running twin sidedraft dragons."
