Results 1 to 8 of 8
  1. #1
    Default "Is there a place where I can
    "Is there a place where I can look up the specs and ratings on older Mercruisers? I am in the market for a used boat and I'd like to be able to look up information on each motor. For example, the latest boat I found has a Mercruiser 260/V8. I believe its a 350 ci with a HP rating of 260 (so I guess some motors show displacement and others show HP rating?). It has an aluminum 19 pitch prop and drives a 21' Eliminator no more than 50 MPH. Seems slow. Is it the motor or the prop? Its mounted to an Alpha One. The seller claims I can get more speed with a different prop. ??? Thanks for any help!!"
  2. #2
    Join Date
    Feb 2007
    Location
    Aruba
    Posts
    15
    Default Your guess is correct about th
    Your guess is correct about the 260 being a 260hp 5.7L SBC. 50mph doesn't sound too far off. Changing the prop may get you more top end at the expense of the bottom end. Don't know of a listing off all the merc engines by model number. I usually research when I'm looking to find what a particular motor is. Then the S/N is very helpful.
  3. #3
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,444
    Default "50mph out of a 260hp, 350cid,
    "50mph out of a 260hp, 350cid, 5.7l, in a 21' boat,+ an Alpha drive is doing Pretty Good.......
    I Really Doubt there's Any more MPH to be Found.....
    Just How Fast do you Expect to Go,..??..
    Or,...
    How Fast do you Want to Go,..??...."
  4. #4
    Default I would have thought with a 35
    I would have thought with a 350 that 60 MPH would be more likely. Thanks for the info.
    I might run the exhaust through the transom. Will that increase HP any?
  5. #5
    Join Date
    Apr 2006
    Location
    Posts
    861
    Default "The speed will be determined
    "The speed will be determined by the hull's efficiency. If it's sleek and streamlined, it should go fast and if it has a step in the hull, it'll go faster. If it's round and bulbous, the wetted surface will be greater and will take more to get it going, and to go fast."
  6. #6
    Join Date
    Dec 2006
    Location
    Posts
    5,444
    Default "[quote]I might run the exhaus
    Nope,.... Not Really,..... It'll just Sound like it's More Powerful......"
  7. #7
    Default "I ended up buying this one fo
    "I ended up buying this one for under $7500. This boat appears to have been very well maintained (always garaged, original paperwork from factory, etc). We checked it out thoroughly. I appreciate all the info that everyone posted. I'll probably do a few upgrades (thru-exhaust, headers-maybe?, stereo, etc). Similar boats are going for $10k. I had two boat owners/mechanics inspect it for me! Can't wait to get it out on the water...
    http://cgi.ebay.com/ebaymotors/ws/eB...263&rd=1,1"
  8. #8
    Join Date
    Dec 2006
    Location
    Posts
    5,444
    Default "That's a Sweet Looking Bo
    "That's a Sweet Looking Boat,......
    Good Luck,+ Enjoy......"
Similar Threads
  1. Need torque specs and plug gap info
    By sledhead67 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-03-2009, 10:05 PM
  2. Mercruiser ford 233 carb specs
    By kinghans in forum Mercruiser Sterndrive Archive
    Last Post: 08-02-2009, 09:48 PM
  3. 1986 Baja Sport 200 Shifting Problems Chevy 350 260v8 Alpha One
    By mmorris4200 in forum Mercruiser Sterndrive Archive
    Last Post: 04-08-2008, 07:46 AM
  4. Mercruiser specs For a 1977 37 470 mercruiser
    By daveolejnik in forum Mercruiser Sterndrive Archive
    Last Post: 02-25-2007, 07:16 PM
  5. Replies: 0
    Last Post: 06-29-2000, 11:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
