Results 1 to 7 of 7
  1. #1
    Join Date
    Feb 2007
    Location
    Madrid, IA, USA
    Posts
    3
    Default "Greetings, wish I was coming
    "Greetings, wish I was coming here under better circumstances, but unfortunately I need help with a fix instead.
    I have a 1986 Johnson J40ELCDE. While duck hunting last fall I had an unfortunate encounter with a log or something hard while up on plane. The collision knocked the motor up out of the water locking it in the tilt up position. The resulting inspection revealed that the prop would not turn freely, with light pressure it will skip along the teeth of the gears. The shifter still shifts between F-N-R with no problems. There is no visible damage to the lower unit housing. I've been told by a friend that I've done something to the lower gears. Is that a correct diagnosis?
    Secondly, I've found a reconditioned 1982 lower unit from a 50 hp OMC. By the information I've been able to gather, this should be compatible with my motor. Can anyone verify that?
    Thanks!"
  2. #2
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "What you have,is basically,a
    "What you have,is basically,a de-tuned 50 hp.I would bet on a shattered clutch dog..!I do believe,that other unit, will go right on there.Be sure to install a new water pump kit in any way you go,while u have it off."
  3. #3
    Join Date
    May 2006
    Location
    pensacola, fl., u.s.a.
    Posts
    1,366
    Default in fwd. gear prop should "
    in fwd. gear prop should "skip" if turned fwd. should lock-up if turned in REVERSE. same (only different) for reverse. should spin free in nuet. check before investing in new lower.
  4. #4
    Join Date
    Nov 2006
    Location
    blaxland, bue mountains NSW, AUSTRALIA
    Posts
    94
    Default revenge of (rambo duck)
  5. #5
    Join Date
    Feb 2007
    Location
    Madrid, IA, USA
    Posts
    3
    Default "Thanks guys.<[img]"http://www
    "Thanks guys.
    I got a really good deal on the other lower unit, actually less than what a new set of gears cost. It has been completely gone through, new seals, water pump, pressure tested, etc. Got it from a guy who is reducing inventory in anticipation of retirement. His son indicated to me that getting the shift linkage loose and hooked back up can be a real pain on these motors. Anyone have advice on how to best go about that and minimize that pain?!?"
  6. #6
    not-a-student's Avatar
    not-a-student Guest
    Default There is no pain at all. Just
    There is no pain at all. Just remove the starter and it becomes easy.
  7. #7
    Join Date
    Feb 2007
    Location
    Madrid, IA, USA
    Posts
    3
    Default That is what I have been told.
    That is what I have been told...
Similar Threads
  1. 1986 40 Mariner lower unit removal
    By kuntrywilli in forum Mercury Mariner Outboard Forum
    Last Post: 12-23-2013, 07:41 AM
  2. How do i change oil in lower unit of 1986 43 omc cobra
    By nick williamson in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-28-2008, 11:01 PM
  3. 1986 90 hp lower unit replacement what will work
    By bassdean in forum Johnson Evinrude Outboard Archive
    Last Post: 06-12-2006, 02:21 AM
  4. Looking for OMC lower Unit 1986
    By Ken Black in forum OMC Sterndrive and Inboard Archive
    Last Post: 02-19-2006, 05:39 PM
  5. 115 1986 Lower Unit Removal
    By Frank Sanfilippo in forum Archive 2003-2009
    Last Post: 04-20-2003, 02:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
