northrivergeek
"I posted this message, or a s
"I posted this message, or a simular one last night but didnt see it listed so not sure if it posted or not so here is my dilima, I replace the water pump, of course putting the gear shift in reverse to gain access to the shifter screw, when done with pump reassembled it all, and too it out for a spin, all I have is reverse, no neutral, just reverse, so obviously the screw didnt get back in the shift rod hole, its a 1987 erude xp 150, whats the trick to get the screw back into the shift rod hole, does the bend in the shaft with the hole face towards the front of the boat or back towards the prop ? do I need to pull on the shaft or some other trick to get it the shift screw and shift rod to line up ?"
