200 merc opti water in air rail
J
JasonAnderson
Guest
" I am a young mechanic workin
" I am a young mechanic working for a dealership but am having finding help with this one, water is leaking into the air rail threw the compresser, I have pulled it apart 3 times replaced all the o-rings, tested staightness off block and head, and checked for corrosion. every time it will run fine for a few minutes before then starting to idle bad again. I know the water is coming from the compresser becouse when I pull the head off I can see the water there, any ideas what I am doing wrong? "
