S
Sheldon Guetling
Guest
"I have a 225 johnson (198
"I have a 225 johnson (1988) that will not run over 4500 rpm. I bought it used and turned out the guy I bought it from is a hack.I put it in the water yesterday to check timing and it was at 24 to 25* at wot but manual calls for 18*+/-1*. I backed timing down and then it would'nt run over 3000 rpm so I put it back where it was. The person I bought it from claims to have replaced the flywheel/timerbase,etc with parts from a johnson GT150. Would they physically interchange? If they do fit my manual calls for 28-32* total timing, depending on which year 150 the parts may have come from. I'm thinking this may be the reason for the low rpm's, that this timerbase if it is from a 150 needs more advance. Any way to I.D.these parts? Thanks, Sheldon"
