Turbo
R
rik
Guest
"i removed the air inlet,no ch
"i removed the air inlet,no chang.
also removed exhaust houseing and ther is no broken or dented blades and they spin freely.
after cruiseing it is the same."
"are you haveing eny white or
"are you haveing eny white or black smoke from this engine,is this problem something that just started,what engine modle is this,check for full thrttle on engine."
"no smoke,this problem jast st
"no smoke,this problem jast started,the engine computer will protect the engine by holding low rpm ,the model is detroit 760 hp dedec the boat is a 55 sunseeker camargue"
