Omc lower unit removal
hughb
Having trouble removing lower
Having trouble removing lower unit from upper gear case. all bolts removed unit separates by dropping
about 1 inch.
Is this all that it will go untill shift rod is turned 90 degrees. unable to turn shaft 90 deg.
manual does not state how much lower unit should separate to disengage shift rod.
sterndrive is 1987 for 3lt
"If You are talking about a Co
"If You are talking about a Cobra, You have to remove the drive from the boat first! (6 nuts and trim cylinder rod). Then pull the drive out!"
Just curious but do you have t
Just curious but do you have the outdrive removed from the boat because you do this while the drive is still atatched.
hmmmm....same timestamp Morten but you must have beat me by a few seconds!
