"But, are you having fun yet?
"But, are you having fun yet? Biggest surprise for me was when I took one of the rod caps off for the first time, and had pin bearings fall out all over the place. Never expected that. One other thing they may not teach you in the books is the importance of using a torch to loosen stuck bolts. They wring off very easily, yet with some well placed heat, many times you can avoid that. Another surprise, was that much of what you replace as a matter of course when rebuilding an auto engine--you would not normally do on an outboard. The main bearings come to mind. On an auto engine rebuild, they are always replaced. On an outboard, they are generally replaced only if necessary. (The price can be sobering!)"
