S
scott evanoff
Guest
" my motor is dying when i put
" my motor is dying when i put it in drive I've had the jets cleaned,check the spark, check the compresion it was all good,I've changed spark plugs, but it will start and run in idle ok it will sit there run fine then the motor will bogg down,kind of chirp like it wants to back fire or die. then goes back to a regular idle. i found out if i pull the out shifter to the netural and riv the motor a little then but push the handle back in sometimes it will let me go after it sputter& kicks what else can i do without trying to pay a arm in a leg for costly mec. bill ..... "
