What other engines fits a bell housing from a GM 350
donnie
" I am in process of swapping
" I am in process of swapping out twin crusader gm 350 engines. of 197? - 1985 vintage. 4 bolt main, 2 piece rear main seal. I would like to go to maybe a carb'd 305 vortec style. What engines will bolt up to the bell housing that came from the 350.
Thanks. "
"The 305 is the same block, ju
"The 305 is the same block, just a smaller bore, so it should bolt up. I think the 4.3 V-6 also has the same bellhousing pattern.
" All late model GM marine ver
" All late model GM marine version gas v/8s use the same bell housing, this encludes 7.4, 8.1 and 8.2 "
"Actually,.......
ALL Chevy
"Actually,.......
ALL Chevy Bellhousing Bolt Patterns ARE the SAME..........
From the Old 235 6 cylinders,... All the way to the New 4.8ls,+ the 5.3ls, Etc.......
There Are several Other differences,.....
But,...
ALL the Bellhousings are the Same........
Only the Big Blocks use 1 Extra bolt at the Top,... But it's Not really needed........."
Can you bolt a 308 out of a bu
Can you bolt a 308 out of a buick to a 79' reinell tri-hull
