Results 1 to 2 of 2
  1. #1
    Default " Hi Joe, The leg was repla
    " Hi Joe,
    The leg was replaced on my 8HP Johnson. Since then, the kill switch will not stop the engine. I need to cut the fuel supply to stop. I assume it has something to do with the ignition wiring, or the switch itself. How should I proceed? "
  2. #2
    Join Date
    Dec 2002
    Location
    Posts
    294
    Default " Robbo;Make sure the black/ye
    " Robbo;Make sure the black/yellow wire connector is plugged in properly and that the switch ground is attatched.To test the switch connect an ohmmeter between those 2 wires,open circuit until switch is depressed then you should have a closed {near 0 ohms} circuit.Zeke "
Similar Threads
  1. 1988 VRO 90 HP johnson kill switch
    By dazieff in forum Johnson Evinrude Outboard Archive
    Last Post: 09-04-2009, 11:36 PM
  2. Evinrude 175 fitch 1999 kill switch not working
    By ricc in forum Johnson Evinrude Outboard Archive
    Last Post: 10-24-2008, 12:27 PM
  3. 1987 20 HP Johnson kill switch
    By noteware in forum Johnson Evinrude Outboard Archive
    Last Post: 08-26-2008, 06:44 PM
  4. Installing a kill switch for johnson 70 vro
    By bassman118 in forum Johnson Evinrude Outboard Archive
    Last Post: 02-04-2006, 03:15 PM
  5. Kill Switch on 8HP Johnson
    By robbo in forum Outboard motors archive 2000-2004
    Last Post: 03-30-2003, 09:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
