Results 1 to 6 of 6
    Mar 2003
    Sydney, NSW, Australia
    20
    Default " I have twin 95 mariners 135h
    " I have twin 95 mariners 135hp that both seem to be running at half power WOT is only 4000 rpm
    and have a hard time getting on plane. But when on idle will rev up to 5000 rpm.The engines are not running hot.
    Replaced fuel filters at motors, replaced racor fuel water seperators and the sight glass tells me they are getting fuel. it acts like the powerpack is bad. but on both motors???? they idle rough. checked for loose grounds.
    Is there an hi or lo governor or something electronically that could have gone bad and utilizes only 3 cyls instead of 6??
    hope somebody can give me a sequence to trouble shoot with a DVM
    Txs in advance "
    Dec 2002
    294
    Default " Ray;Is you boat bottom foule
    " Ray;Is you boat bottom fouled,barnacles,weeds other crap ??????? "
    Default the boat is clean it acts lik
    the boat is clean it acts like when taking off that both hubs are spinning
    Default jupiterzeke also i used to b
    jupiterzeke
    also i used to be able to get on plane on one motor
    Default Re: " I have twin 95 mariners 135h
    Quote Originally Posted by ray View Post
    Txs in advance "
    So what was the outcome of your problem? I have a 2002 Mercury 115hp outboard that once I get it up over 4000 rpms drops rpms back and forth between 4700-4100, and sometimes will not get up on plane, I've had the carbs cleaned, reset to factory, new fuel pump , trigger , stator and regulator, bad wiring also replaced , to no end
  6. #6
    Dec 2015
    maplevalley WA
    5,049
    Default Re: 135 mariners twins both low on power
    Have you checked the double bottom for water intrusion? Normally two engines will not have the same symptoms that points toward the hull? Do a survey of the deck and transom looking for dryrot.
  1. 74 L 330 trs twins cutting in and out on top end
    By wayned800 in forum Mercruiser Sterndrive Archive
    Last Post: 08-25-2009, 10:45 AM
  2. Mariners have me totally confused
    By fastjeff in forum Mercury Mariner Outboard Archive
    Last Post: 03-23-2009, 04:49 PM
  3. b93 Black Max 175hp Twins Power Bleed
    By chrisd in forum Mercury Mariner Outboard Archive
    Last Post: 07-27-2007, 10:23 AM
  4. 30 twins vs single 57
    By sean_k in forum Volvo Penta Gas Archive
    Last Post: 10-13-2006, 09:04 AM
  5. MCM 170 twins
    By Bobby Miller in forum Mercruiser Sterndrive Archive
    Last Post: 04-24-2006, 04:51 PM
