Results 1 to 4 of 4
  1. #1
    K.M.bever's Avatar
    K.M.bever Guest
    Default I'm restoring a wooden ru
    I'm restoring a wooden runabout. I've got a chevy 348 cid engine. I like the looks of the engine.
    I want to put the motor in the boat. Where do I find the manifolds and the trany for this engine?
  2. #2
    Join Date
    Feb 2010
    Location
    McHenry, Illinois, USA
    Posts
    75
    Default " Pacemaker marinized 409s, se
    " Pacemaker marinized 409s, several parts are interchangable. They're hard to come by though. Usually has a 2-1 or bigger gear. You'd be better off in the long run starting fresh with a more modern V-8 "
  3. #3
    KM Bever's Avatar
    KM Bever Guest
    Default Where would I start to look f
    Where would I start to look for marine parts or maybe a 409 marine engine. The reason I looking at these motors is how they look. I'm after a 50's look.
    Bever
  4. #4
    Join Date
    Jun 2000
    Location
    Forest Dale, VT, USA
    Posts
    1,681
    Default "Bever, You could post a wa
    "Bever,
    You could post a wanted and in the classifieds here and elsewhere.
    Regards,
    Andrew
    [img][/img]"
    Andrew Menkart
    MarineEngine.com
    "There is no situation in which knowledge is more truly power than at sea."
    - Lord Brassey
Similar Threads
  1. 10 Hp 4 stoke on an 18' lapstake runabout
    By georgel in forum Honda Outboard Forum
    Last Post: 08-08-2010, 11:38 AM
  2. Motor size for an 18 ft lapsrake runabout
    By georgel in forum Miscellaneous marine engine topics
    Last Post: 11-13-2009, 03:07 PM
  3. Cc 17 runabout 1939 k engine
    By spike13 in forum Chris Craft Engine Forum
    Last Post: 06-25-2009, 01:27 AM
  4. Repowering 57l 1989 Mercruiser to a new Chevy
    By saffari in forum Mercruiser Sterndrive Archive
    Last Post: 02-18-2009, 04:44 PM
  5. Repowering w small block chevy alpha or bravo outdrive
    By masterbaiter88 in forum Mercruiser Sterndrive Archive
    Last Post: 01-06-2009, 01:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
