Evinrude 85 hp 69 shifting problem
R
Richard Dahlsjö
Guest
" Hello,
I have a problem wit
" Hello,
I have a problem with my evinrude the shifts doesnt work. I checked the blue & green wires at the knife connectors, its power to the knife connectors (knife connector to ground). But if I break the connectors and takes a electric checker between them (green wire) there is no power??
Excuse my english, im from sweden.. "
"Richard..... The following ma
"Richard..... The following may be of use to you. Let us know how you make out.
(Hydro Electric Shift)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Preminum Blend" lube, commonly called "Type C". (A thinner lube)
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
Joe
" Hi again, I have already che
" Hi again, I have already checked all that and it doesnt works any way? The blue wire gets power but not the green one.. "
Flush the unit and change you
Flush the unit and change your oil and then check again before you go any further
