Tony outboard
alan
tony
went out in the boat to
tony
went out in the boat today and had the same problem althought we have got to no missfire but just running on 2 cylinders
heaps of spark for number 3 cyl but no go with all the things that are happening maybe i am getting water into the intake on the crankcase?
as number 3 had a different colour (Brown)
has me beat
what do you think?
" Alan,
If water is getting
" Alan,
If water is getting into #3, you should see a heavy, muddy deposit on the spark plug.
Usually, the water would be getting in through the exhaust ports. It could be due to a worn gasket on the exhaust cover or plate, or a badly corroded surface on either of these two parts, or on the block itself.
This assembly is on the port side of the block.
Tony "
