Results 1 to 8 of 8
  1. #1
    Mike Bunch's Avatar
    Mike Bunch Guest
    Default I'm stuck. Sears no long
    I'm stuck. Sears no longer carries parts for my 7.5 HP Gamefisher outboard. I need a carburetor. What do I do?
  2. #2
    Join Date
    Dec 2002
    Location
    Posts
    294
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    13,931
    Default "Mike..... I'm curious. Wh
    "Mike..... I'm curious. Why would you need a new complete carburetor? Is it missing or broken somehow, or does it simply need cleaning and rebuilding?
    Joe[img][/img]"
    We occasionally have questions. If you fail to answer, it may affect ours.
  4. #4
    Join Date
    Nov 2005
    Location
    Posts
    66
    Default " Mike: a lot of those old Gam
    " Mike: a lot of those old Gamefishers were made by Chrysler and some were made by Tecumseh. Parts are available for both. Maybe not a complete carburetor, but certainly some carb kits.The Tecumseh outboards were air cooled - the Mopars were water cooled. With some more information, like a model number or what is acually wrong with the carb would be helpfull. Good luck. "
  5. #5
    Default " Thanks guys. The motor used
    " Thanks guys. The motor used to run great, but it sat for 5 years. I will clean the carburetor and attempt a kit if I can get one. But in the long run, I probably should look to give it away and buy something else. Thanks for the info on Chrysler & the Japanese companies. "
  6. #6
    Default " hey I also have a 19? 7.5h.p
    " hey I also have a 19? 7.5h.p. Gamefisher if you give it away, let me know, i really need a flywheel key.
    Thanks,
    Jordan "
  7. #7
    Kathy Wooster's Avatar
    Kathy Wooster Guest
    Default " I have a 5 HP Gamefinder wit
    " I have a 5 HP Gamefinder with only a partical ending numbers, can anyone tell me where i can find out what year it is? also, There is a place in Detroit, Michigan called Discount Marine, the phone number is (248) 588-0633 ask for Sherwood Taylor. Sorry i only have the phone number. I under stand he carries carborator gaskets and re-build kits for this motor. "
  8. #8
    Dutch Earle's Avatar
    Dutch Earle Guest
    Default I need a gas line adaptor for
    I need a gas line adaptor for a 5 HP Gamefisher;
    Where can I find one?
    Someone gave this motor to me and I'm trying to see if it will run; I have the fuel line but no male adaptor to connect it too a gas tank.
Similar Threads
  1. Sears Ted Williams motor parts carb parts Where can I find parts
    By ajohnson in forum Ted Williams Outboards
    Last Post: 08-11-2014, 12:32 PM
  2. Sears gamefisher 30
    By ted1199 in forum Gamefisher Outboards
    Last Post: 08-26-2008, 05:29 AM
  3. Gas cap for Sears Gamefisher 35
    By drumsandkeys in forum Gamefisher Outboards
    Last Post: 07-09-2008, 08:50 AM
  4. Sears gamefisher 99 parts owners manuel year
    By hayden442 in forum Archive 2003-2009
    Last Post: 10-12-2003, 01:51 PM
  5. Sears Gamefisher
    By Don Martin in forum Outboard motors archive 2000-2004
    Last Post: 05-28-2002, 03:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
