J
Joe Schmidt
Guest
I noticed while winterizing t
I noticed while winterizing the engine for the season that the transmission makes a scrapeing sound and will turn the prop shaft slowly if the motor is reved a bit while in neutral. The tranny and engine functioned fine last season. I changed the fluid last spring. It had good color and odor. (still does) The fluid I used was Valvoline Dextron III. I noticed the bottle said it had "shutter protection". Could the fluid be causing this? I checked the shift arm on the tranny and it is in the correct postion. Fluid level is fine. Do you think the tranny is ready to fail? I want to take care of this prior to April launch to have a hopefully trouble free season.
The boat is a 1977 Chris Craft Catalina 251 with a 305K motor. As always thanks for your help.
Joe
Joe
