B
Bob Kelly
Guest
" Have my 8 HP Hicks mounted o
" Have my 8 HP Hicks mounted on an trailer and running great. This engine shows very little wear but the outside of the cylinder has three cracks in it. When I purchased the Hicks in Nov of 2002 the piston was stuck (sleeve collapsed). Removed the piston and had the sleeve reamed so that part works fine. However, the three cracks are continuing at an alarming rate. One has grown about 4 inches in three months. Have V cut the cracks and drilled the ends but the cracks continue. Have water in the engine now at all times but it seeps out through the cracks. Can live with the cracks as they do not affect the engines performance but would like to make it water tight. Any ideas? Thanks in advance for any help you may send my way.
Bob Kelly--Lompoc, CA "
