B
ButchHarrell
Guest
"Had the sensor replaced 12 mo
"Had the sensor replaced 12 months ago and now oil leaking around the sensor as it fits from the bottom of the oil resevoir. There is what appears to be a plastic compression type fitting in the hole the sensor slides up into and secured rather crudely with a sheet metal screw and small metal disk. Do I have to purchase a new take or new sensor to get this leaked stopped. I cannot tell by looking at exploded views of take, sensor assembly. Thanks much"
