"I aquired this unit from a Jo
"I aquired this unit from a Johnson 150HP and wanted to try it on the bench before installing it on my motor. This unit has 3 wires (black, blue, and green)and has two trim rams with the large tilt piston in between. I placed direct negative to the black wire and alternated direct battery between the blue and green. The problem is that while the trim rams move up and down the main piston always moves in the up direction. The only way to lower it is to bleed the lower side of the piston. Does the unit need the weight of the engine to return to the down position or should the piston pull in by itself? The unit is normally wired with a solenoid but I don't think that should be affecting me for this test. The wires I'm using should be more than adequate for about 30 to 40 amps. Any help would be appeciated. Thank you.
Mike"
Mike"
