Results 1 to 8 of 8
  1. #1
    Default "My son an I just recently bou
    "My son an I just recently bought a boat and this 85 HP motor. It really needed alot of TLC. The one thing we do want to do is replace the water pump. I have a complete pump kit and want to know if someone can tell me the exact replacement procedure from start to finish. Is there a web site that could provide this, or hopefully one of you reading this? We did start the motor momentarily and noted that we had no water coming out of pee hole. Thanks You!"
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,212
    Default "The water, on a engine that s
    "The water, on a engine that size, must be turned on full force when running the engine on a flushette.
    The water telltale outlet has a habit of becoming clogged with salt, foreign material, etc. Clean out the fitting and hose to make sure all is clear.
    Purchase a service manual to obtain full information pertaining to replacing the water pump assy. That can get a little involved in explaining every detail of that procedure here. However......
    The shift rod must be disconnected at the area under the bottom carburetor (3/8" shoulder hex bolt). Four obvious bolts at the lower unit side areas must be removed. Remove the 5/8" hex bolt under the cavitation plate, the trim tab, and a bolt under the trim tab. That should allow you to drop the lower unit.
    NOTE: DO NOT TURN THE LOWER UNIT SHIFT ROD! The measurement of the shift rod in neutral from the top surface of the lower unit to the top center of the shift rod hole is critical and must be exact!"
    We occasionally have questions. If you fail to answer, it may affect ours.
  3. #3
    Default "Thanks Joe, I realized tha
    "Thanks Joe,
    I realized that I would have to opt for a repair manual however, I do appreciate the added information you provided. Those little incidentals go along way when doing a job correctly; again thanks. Krusty"
  4. #4
    Join Date
    Mar 2004
    Location
    Posts
    385
    Default "<[img]"http://www.marineengin
    This is the bolt that joe was refering to."
  5. #5
    Join Date
    Mar 2004
    Location
    Posts
    385
    Default Sorry guys I am going to have
    Sorry guys I am going to have to say I have posted the wrong picture here because the 78 was different and I will look in my notes and find the right one I hope. sorry for the misinformation.
  6. #6
    Default "Williard, Thanks for the inp
    "Williard,
    Thanks for the input. Hope you can find the
    picture showing this bolt. Krusty"
  7. #7
    Default "Joe, I see where you mention
    "Joe,
    I see where you mentioned the cleaning of the fitting and tubing leading from the water pump.
    Would I use a wire such as a clothes hanger or maybe compressed air. Any idea how long this tube is, and is it the tube I see near the top of head?"
  8. #8
    Join Date
    Feb 2001
    Location
    Posts
    14,212
    Default The fitting and tube I speak o
    The fitting and tube I speak of is the plastic fitting at the starboard rear of the hood pan. This has a short rubber tube attached to it which leads to the bottom portion of the exhaust baffle plate.... the large plate between the cylinder heads.
    What is the model number of that engine? I cannot visualize any tube you speak of near the top of the head.
Similar Threads
  1. 1971 Evinrude 6hp Waterpump
    By jack57 in forum Johnson Evinrude Outboard Archive
    Last Post: 10-31-2008, 05:41 AM
  2. 25hp 1985 Evinrude waterpump
    By Ned Dixon in forum Johnson Evinrude Outboard Archive
    Last Post: 12-18-2006, 03:01 AM
  3. 92 evinrude 6hp waterpump
    By blueboat1 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-19-2006, 12:01 AM
  4. Waterpump 1972 evinrude 100HP
    By Peter Silkin in forum Johnson Evinrude Outboard Archive
    Last Post: 04-06-2004, 09:06 PM
  5. Evinrude waterpump removal
    By tim barnett in forum Johnson Evinrude Outboard Archive
    Last Post: 06-09-2003, 09:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
