Results 1 to 5 of 5
  1. #1
    Dillon Offutt's Avatar
    Dillon Offutt Guest
    Default I have a 25hp johnson 2004 2 s
    I have a 25hp johnson 2004 2 stroke short shaft and i would like toknow everything i could possibly doto make it faster i have a solas ss prop 12 pitch but i need this motor to be as fast as possible for where i duck hunt there is a 25 hp limit and everyone is blowing past me i also have power tilt and trim and this is on a 15 42 war eagle boat any information would be greatly appreciated
  2. #2
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default "we need pics of motor setup o
    "we need pics of motor setup on the transom
    the higher up the motor is on the transom the faster u will go, but u could cavitate and over heat
    what is ur WOT rpm?
    also when u go WOT, do u trim it out?"
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  3. #3
    Join Date
    Jun 2006
    Location
    Treasure Coast, FL
    Posts
    127
    Default I'm betting you can put a
    I'm betting you can put a lot more prop on that boat. At least a 10/13 and probably even a 10/15. I would go with the 15 for starters. Do you have a way to check your RPM's?
    IE: I run a older 35 Johnson on a 13 Whaler with a 10/15 and it will run just over 30 MPH at WOT. Boat and motor with gear are around 550 lbs. and the cavitation plate is 1/2" below the bottom of the transom.
    See if you can find a place to test some different props.
  4. #4
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "The best props I have found t
    "The best props I have found to use on those models are the 4 blads used on the 3 cylinders 25/35 engines. A bit pricy, but worth it."
  5. #5
    Join Date
    Nov 2006
    Location
    blaxland, bue mountains NSW, AUSTRALIA
    Posts
    94
    Default buy your ducks from the super
    buy your ducks from the super market.
    it will make the live ones a bit happier
Similar Threads
  1. Going faster
    By dmanars in forum Volvo Penta Gas Archive
    Last Post: 01-22-2009, 03:33 PM
  2. Wanna make my motor faster
    By 00dan in forum Johnson Evinrude Outboard Archive
    Last Post: 06-20-2008, 01:26 AM
  3. Year and make of my 25 hp johnson outborad
    By MarekWodz in forum Johnson Evinrude Outboard Archive
    Last Post: 05-18-2004, 07:15 PM
  4. Year and make of my 15 hp johnson outborad
    By mike roberts in forum Johnson Evinrude Outboard Archive
    Last Post: 05-16-2004, 08:44 AM
  5. Going Faster
    By rich in forum Outboard motors archive 2000-2004
    Last Post: 09-21-2002, 02:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
