Water separator Question
whfmznb
" Is there a water separator f
" Is there a water separator for portable OB's...
perhaps something that will be inline with the fuel hose...like a RV water filter. Or is this a concern with,say, a 25hp or less? Thanks... "
" A filter/water seperator is
" A filter/water seperator is definitly a good idea for any setup where it's practical to put one in. They have the benifit of filtering water, but also are just much higher quality filters. The only time it might not be practical is if you have an outboard with a self-contained tank.. still, you could possibly add something under the cowl. With a small engine that has a portable exterior tank, easiest thing to do would be to just mount the filter to the boat (upright position) and make it so you have quick disconnect fittings to allow for removing tank/OB etc. Just be sure and put the primer bulb before the filter in the path to the OB.
Jon "
