" Most of the 2-stroke 25'
" Most of the 2-stroke 25's (not sure about 4-strokes) are 2 clyinders; as for the mercs, the 20 & 25 weigh the same and so do the 25 & 30 Johnsons, all these engines are around 125 lbs, all solid designs. When shopping for one in this range, I considered the merc 4 strokes because of the price and free extended warranty; I was actually told at two shops that these sized 2-strokes just don't really break and I wouldn't need it with them anyway.
The Johnson and Merc 10-15 HP two strokes are also in the same weight range - around 75 lbs. I think the Merc 15 HP four stroke is pretty light, under 100 lbs.. a decent subsitute for a 2-stroke weight wise. If weight is an issue, I would stick to 2-strokes though.
Merc's will run you a little less, competing in price with those Nissan/Tohatsu. I looked at a few merc 25's that were a season or two old, and had been run in the salt - it was pretty disgusting, so I set my sights on the Bombardier/Johnson/Evinrude. I think for fresh water it wouldn't make a difference, those are very popular engines. The nice thing about merc is you know the parts will be readily available 99% of the time (price is another story, but that's outboards).
As for that boat.. what's it have in it other than aluminum? To give you an idea, I have a 16 foot (aluminum) starcraft holiday I've been restoring and converting to a center console; it is rated for an 85 HP. This boat does have a wooden floor with some seating etc.. but, it's only a couple feet longer and aluminum - how much difference does that make? It seems that 14 footer might be best powered by the 25 HP two stroke.. I wouldn't think that the extra 50 lbs from engine would make a big difference at all. One option though is w/ electric start, get longer cables and put the battery up in the bow, that should solve the planing problem.
Jon "
