Phantom 8175
D
Donald Axelsson
Guest
I want some information and d
I want some information and documentation of my old motor Graymarin 8-175.
"Donald,
Are you sure it is
"Donald,
Are you sure it is a Phantom 8-175?
There was a Fireball 8-175 as follows:
<UL>[*]175HP [*]Max RPM 4000 [*]287 cid [*]2-Bore Carb [*]Avg. Wt. Direct Drive: 900 lbs. [*]Avg. Wt. Red Gear: 945 lbs.</LI>[/list]
Regards,
Andrew"
" Hi Andrew!
Yes I'm sure
" Hi Andrew!
Yes I'm sure it is a Gray motor.
The specifications are:
Bore 3 5/8
stroke 4 1/2"
372 cubic inches
Phantom eight developes 175 hp at 3.400 r.p.m.
Certified weight,aluminium base and housings
1110 lbs.Iron = 1250 lbs.
2 carburetors independent of each other feeding
its own 4-cylinder engine.Individual intake ,manifold passages ond ports.
Adjustable main jets are used.
Hope for an answer.
Donald Axelsson. Sweden "
