Results 1 to 5 of 5
  1. #1
    Ron Schuller's Avatar
    Ron Schuller Guest
    Default " I was in rough water over th
    " I was in rough water over the weekend and was heading back to the landing when I noticed my top end speed had dropped about 10 mph. RPM was still the same. I tried adjusting the trim because of the rough water, but that didn't help. I was thinking spark plugs and I talked myself out of that thinking my RPM would have gone down. Same thought pattern for fuel pump. The engine didn't seem starved for gas. Please help! "
  2. #2
    Join Date
    Nov 2005
    Location
    Posts
    424
    Default " Rough water is going to do a
    " Rough water is going to do all sorts of things; your prop may be coming out of the water, the boat might be fighting wind and/or current and must plow through chop. If you are using a non-gps speedometer, one that actually uses the water, it's not going to work right either, as it will not have constant water contact (they never work accurately anyhow).
    If you take it out in calm water, and something still seems to be wrong - your prop's hub may be slipping or damaged. To check for slippage, you can either mark the prop nut/prop and see if it changes or use a 2X4 between the prop, trim tab, and lower unit to lock the prop, put the engine in forward (NOT running) and attempt to turn the flywheel nut (clockwise). If the flywheel turns without the prop, your prop hub is damaged.
    Jon "
  3. #3
    Join Date
    Feb 2002
    Location
    Posts
    107
    Default " Rough water will slow your e
    " Rough water will slow your engine down. I was worried about mine this spring. Mine's a 15HP Johnson, and we were out in the gulf when it got rough, and even at WOT, we weren't going much over 10MPH. Tried it in calm water a few days later and no problems. I don't think you ahve to worry unless this problem persists. "
  4. #4
    Ron Schuller Guest
    Default Thanks for all your help. I&
    Thanks for all your help. I'm going out this weekend and will be crossing my fingers.
  5. #5
    Ron Schuller Guest
    Default " Went out Sunday and she ran
    " Went out Sunday and she ran fine. Much better conditions; although, the fishing was tough. "
Similar Threads
  1. Lost 1/2 [email protected] full speed 1985 50 hp
    By bill murrin in forum Johnson Evinrude Outboard Forum
    Last Post: 11-29-2010, 11:03 AM
  2. Replies: 2
    Last Post: 08-21-2009, 10:19 AM
  3. Force 90 lost compression
    By John Neptune in forum Chrysler Force Outboard Archive
    Last Post: 03-06-2006, 09:01 PM
  4. 1988 50 HP Force suddenly lost PRM amp power HELP
    By John Milliron in forum Chrysler Force Outboard Archive
    Last Post: 03-06-2006, 04:20 PM
  5. 125 Force lost power
    By billbrowder in forum Chrysler Force Outboard Archive
    Last Post: 03-25-2004, 09:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
