Click for Detroit Diesel manuals!
Results 1 to 14 of 14
  1. #1
    rob woodward's Avatar
    rob woodward Guest
    Default I have a bedford diesel engine
    I have a bedford diesel engine and would very much like to get a service manual for it. Please call me collect at 1-604-538-3387 if you get an answering machine please leave your number. Thank you very much.
  2. #2
    Join Date
    Jun 2000
    Location
    Forest Dale, VT, USA
    Posts
    1,681
    Default " Rob, I have a Bedford manua
    " Rob,
    I have a Bedford manual. I will email you directly.
    Regards,
    Andrew "
    Andrew Menkart
    MarineEngine.com
    "There is no situation in which knowledge is more truly power than at sea."
    - Lord Brassey
  3. #3
    Join Date
    Jun 2000
    Location
    Posts
    1,681
    Default "Rob, I don't know your e
    "Rob,
    I don't know your email address, but we do have a manual for the 466 cid Bedford Diesel, here.
    Regards, Andrew"
    Andrew Menkart
    MarineEngine.com
    - Lord Brassey
  4. #4
    Default " Andrew or Rob, Do U have
    " Andrew or Rob,
    Do U have any info on Bedford diesel 300 CID (or maybe 330 CID. I have 2 semi assembled 300 CID engines "
  5. #5
    Neil McDaniel's Avatar
    Neil McDaniel Guest
    Default "Bill, I have a 100 hp, 300 cu
    "Bill, I have a 100 hp, 300 cu in Bedford in my converted fishboat (built in 69). The engine runs very well but I since I only bought it last year I have no idea of its history. I run it at 1800 rpm and get about 7-8 knots at less than 2 gallons per hr. Runs quite smoothly for an old-timer. I have the basic engine manual (not a shop repair manual). There is a company in Prince Rupert, British Columbia that has parts for them.
    If you would like a copy of the manual, drop me a line at [email protected]
    Neil"
  6. #6
    john haakman's Avatar
    john haakman Guest
    Default "HI fellow's JOHN HAAK
    "HI fellow's
    JOHN HAAKMAN FROM AUSTRALIA. I picket up a unfinished 60ft steel yacht.with a 2'n hand bedford 6 cl diesel engine in it. model OB5,
    It has also these numbers on it, elo4 , elo9 ,e200 ,e206 .e207 'e211 'e212 .
    IT HAD BEEN PUT IN ABOUT 12 YEARS AGO, and had not been started sins
    I got it started ,3 time's in qiuck burst's, because I had no water running thru it, then the third time after a few minutes it started to squeal. it sounded good when it was running.
    If any body has any information on this motor,or where I can get information on this engine, I would apricate greatly. JOHN
    If anyone has any books on the motor,great.
    my email is [email protected]"
  7. #7
    Join Date
    Jun 2000
    Location
    Posts
    1,681
    Default "John, I am not sure what m
    "John,
    I am not sure what model Bedford you have... there should be a GM nameplate on the engine with a serial number. If you can supply the serial number we can detirmine the engine specifics. Basically if the serial number begins with:
    <UL>[*]A = 220/330 cubic inch[*]B = 466 cubic inch[*]C = 500 cubic inch</LI>[/list]
    We have manuals for the 220, 330, and 466.
    See if you can get more info and post it...
    Regards,
    Andrew"
    Andrew Menkart
    MarineEngine.com
    - Lord Brassey
  8. #8
    JOHN HAAKMAN's Avatar
    JOHN HAAKMAN Guest
    Default " Andrew, Sorry that
    " Andrew,
    Sorry that I did not writed you back sooner, I was waiting for a email. Today I was looking for Your email, and there was your notice.
    I found out this weekend that the motor is a bedford 330, and allso this weekend I found a motor the same as mine, complety overhaul,a bloke overhauled it for his CONCRETE fishing boat, when it fellover, now he is going to use the boat for land fill.
    I though spare part&#39;s, I will need, if I will be going around the world In a couple of years. ?
    So Andrew, I would appre&#39;ciate any manual&#39;s or information on the bedford 330.
    let me know if I can do anything for you down under.
    John "
  9. #9
    JOHN HAAKMAN Guest
    Default Andrew the s/o on the engine
    Andrew the s/o on the engine is 624741 / p12 50L
    John
  10. #10
    JOHN HAAKMAN Guest
    John
  11. #11
    Join Date
    Jun 2000
    Location
    Posts
    1,681
    Default " I do have Service and Parts
    " I do have Service and Parts manuals for the GM Bedford 330 engine. I will send you an email.
    Regards,
    Andrew "
    Andrew Menkart
    MarineEngine.com
    - Lord Brassey
  12. #12
    mog-e's Avatar
    mog-e Guest
    Default "I have a bedford 500 diesel e
    "I have a bedford 500 diesel engine and desperately need to get a manual for it. If anyone has or knows of where I can get one, the information would be greatly appreciated. I can be contacted via email : [email protected].
    Kind Regards
    Stephen"
  13. #13
    Default Re: " Rob, I have a Bedford manua
    Hi Andrew. . . I, too am looking for a service manual for my 1973 GM Bedford 466 - which powers my 40' trawler. Any suggestions? My email addy is [email protected]. Thank you!
  14. #14
    Default Re: "Rob, I don&#39;t know your e
    Hi Is this thread still active.
    I have a bedford 466 (i believe) and i am trying to find a service manual. I want to rebuild some of the engine. liner, piston rings etc.
    If anyone has a manual i would love a copy sent to hussain.saeed @ recyclingtechnologies dot com
    Also this is all the info i have recovered off the engine. Can someone help me identify if it is a 466 or a 500 please
    The injector design number is :
    BKBL87S5189
    DES no : 5225401
    The engine code is : PN 883 043 / 710 789
    Engine letter : J Second Number : 70
    Quote Originally Posted by andrew View Post
    "Rob,
    Regards, Andrew"
Similar Threads
  1. GM BEDFORD 466 LONG BLOCK NEVER USED
    By BRUCE GOODSITE in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 11-12-2013, 07:35 PM
  2. bedford 330
    By stevo_1 in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 10-27-2012, 06:36 PM
  3. Bedford Diesel
    By David Price in forum Detroit Diesel
    Last Post: 04-12-2004, 09:20 PM
  4. Air Filters for a GMC Bedford diesel 6 cyl 446m
    By Captain Ron in forum Detroit Diesel
    Last Post: 03-01-2004, 12:00 AM
  5. Re power sea ray 340ec with deisels
    By carldalmas in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 08-19-2001, 03:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
