" Well, if you can buy Snap On
" Well, if you can buy Snap On at 60% discount, then thats the way to go. Your salesperson should be able to set you up with a good starter set and build on that as need and funds arise. Having been around cars some as you have, then you have an idea of what to buy first. A set of sockets, both metric and SAE, in 1/4 inch and 3/8 inch drive is a must. Make sure you get a set that has deep sockets as well. A set of combo open end and box end wrenches in both metric and SAE, a good assortment of screwdrivers, a good mess of pliers (needle nose, sidecutting, diagonal cutting,etc, as well as Channellock type), a snapring plier kit that does both internal and external rings, a set of punches, chisels and a few hammers should get you on the road. You will never have enuf tools or of the right size but keep adding, and rule one of a good tool box is NEVER, let anyone borrow tools. You make your living with them and to let them out on loan is not only a crap shoot, but if they get lost, you are out a paycheck as well. Always wipe down (But not too clean, as a slight coat of oil will help keep rust away) tools after each use, and get in the habit of putting each tool in its place. Then before you leave or the boat leaves the shop, you can tell if you have all of your gear. Good luck, Kim "
