Results 1 to 5 of 5
  1. #1
    Join Date
    Jan 2006
    Location
    Posts
    94
    Default " We are trying to identify th
    " We are trying to identify the manufacturer of our 44' 1967 Pacemaker's engines. They are original equipment and are gasoline; V8 O.H.V.; 427 C.I., 320 HP @4000 RPM; 8.8:1 Compression ratio; 130 PSI cranking compression. Also, any leads on finding a service manual would be appreciated. "
  2. #2
    Join Date
    Nov 2005
    Location
    Posts
    190
    Default " During this time frame, both
    " During this time frame, both GM and Ford made a 427. Most likely it is a Ford 427 Interceptor, as they marinised a lot of these motors. Check for casting numbers or serial nos. on block, manifolds, etc and hit the internet. Some good mechanics (who were working on cars in the 60's and 70's) may be able to ID the motor by its looks. Good luck, and let us know what you find, Kim PS What color is the motor??? GM used red/orange and Ford used blue, but this is not a sure thing, just a helping hint. "
  3. #3
    Peter Bruun's Avatar
    Peter Bruun Guest
    Default " Just a quick simple thing, i
    " Just a quick simple thing, is that the Fords had a front mounted distributor. Chevys not.
    Peter "
  4. #4
    Join Date
    Feb 2010
    Location
    McHenry, Illinois, USA
    Posts
    70
    Default Another way to tell is that C
    Another way to tell is that Chevrolet valve covers were on the head only. The Ford covered the head and part of the intake manifold
  5. #5
    Default Re: " We are trying to identify th
    Quote Originally Posted by ted View Post
    I need a piston for a Pacer Marine Engine - a '69 427 Chevy. It's a low domed piston. Any ideas?
Similar Threads
  1. What year was my motor manufactured
    By bkohm in forum Mercury Mariner Outboard Archive
    Last Post: 08-23-2009, 05:44 PM
  2. Who manufactured my outboard
    By bigdaddy81 in forum Mercury Mariner Outboard Archive
    Last Post: 06-12-2009, 08:09 PM
  3. Mercury 98 HP What Year was it manufactured
    By E. Craig Bogle in forum Mercury Mariner Outboard Archive
    Last Post: 05-02-2006, 06:34 PM
  4. Johnson 25 HP outboard Year manufactured
    By E McIntyre in forum Johnson Evinrude Outboard Archive
    Last Post: 03-26-2004, 10:07 PM
  5. Pacer 220
    By robert krahn in forum Archive 2002-2006
    Last Post: 08-01-2000, 06:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
