Engine is a BF30A 1997. Bogging only happens under load; when not in gear the engine will rev up to the limiter just fine no issues. When under load the engine will rev to mid rpm no problem, but as soon as I give it the beans it just bogs down and won't put out any more power. Sounds like the engine is choking. If I do gas it and let it bog out, there is significant power decrease across all rpm for a short time before returning to the normal full power up to mid rpm.
Carburetors have been completely rebuilt, new jets, new gaskets and orings on all carbs and intake. New fuel lines, new fuel filter, new fuel pump. 98% sure there should be no issues fuel side. Compression is good across all cylinders. Checked, doubled checked, tripled checked and it's good. If anyone is wondering, it is 120 psi across all. I know it sounds low, but it is a pull start model and has been that same compression reading since I bought the engine long before I ever had this problem. New spark plugs, old ones not fouled, resistance check on ignition coils showed they are all within spec. Did the old school pull the plug on each cylinder while its running test and all cylinders are firing.
I'm thinking its the CDI, but I can't get a new one and would have to buy used and I really don't want to have to check resistance on all the CDI components. Any thoughts before I pull the trigger on a used CDI?
