I have a 2006 Honda 20HP with power tilt/trim
It has been a great engine, but I ran it into some rocks a while back and since then when I throw it in reverse the engine raises out of the water instead of backing up.
If I use the power tilt and raise it up it works great and the tilt motor pulls down once it hits the top. It's the same if I lower it, goes down as it should and motor pulls down once its at the bottom limit.
If I grab it with my hand and try and raise it up it comes up and then returns to the bottom once I let go. What is going on?
How to I fix it so when I back up it stays locked down and pulls my boat backwards?
Pre Thanks for you help resolving this issue!!!
