Looking a little help....hopefully someone can enlighten me with their wisdom. <br><br>2015 Suzuki DF140 4 stroke......I noticed the engine tell tale stream (pee) was weak. My dealer mentioned it even after he changes the impeller about a year ago. I looked into a descalers, rydlyme solution. Over the last two years, I've over heated a couple of times...primarily due to being in shallow ponds...running over grass....while my jackplate is up. Normal operating temperature is between 143-150 degrees. Engine overheat turns on at 180-183 degrees. Each time I got in shallower areas like I mentioned, I would stop in deeper water and reverse to try and purge the coolant system. I'd always watch my engine temperature drop every time. And I'd never be in a place where I didn't get the temperature back down. Recently, about the last 80 days, I got busy and hadn't been able to get on the water. I took off work last Wednesday (Nov 30th) to go fishing. I put the rabbit ears to make sure my engine was running ok, and I noticed the motor had no tell tale (pee stream). Since then, I've done a lot. <br><br>I ordered 2 gallons of rydlyme, all new water pump pieces: gasket, metal plate, metal bowl, key way, impeller, water pump housing, all gaskets (one for the water pump housing that's inlayed internally, 2 more gaskets (one smaller that goes in before the impeller metal bowl is placed into the water pump housing and the other used between the water pump housing and installing it to the lower unit over the drive shaft with the 4 bolts.....I've removed the lower unit off the engine and replaced all components associated with the water pump. At the same time, I've pulled all my anodes off, pulled the theromstat (checked to see if it opened), and replaced the water pressure valve. With thermostat removed and the lower unit off, I built a coolant cleaning system using a reservoir and a really strong pump. I attached the pump straight to the water pump intake on the motor, removed the engine cleanout plug to attach another hose to feed back into the reservior, and then removed the tell tale (pee) piece...I pulled it off...and put a hose from that that leads back to the reservior as well. I used the 2 gallons of rydlyme with about 2-4 gallons of water. I ran the pump for 2 hours and you can physically see water coming from the tell tale hose back into the reservior. The rydlyme took a ton of mud, crust, whatever out of my engine. I removed all the anodes to see the condition of the internals and everything looked significantly cleaner. I re-installed the anodes, and ran water through system 2 separate times and the tell tale (pee stream) is clear as day with the strong pump pushing water into the coolant system. <br><br>I reattached the lower unit back onto the motor and turned on the motor with rabbit ears over the intake on the lower unit. there's no tell tale (pee stream) and I was thinking maybe it needs to be fully submerged to show a stream coming off the engine. So I got a 40 gallon trash bin and filled it with water and turned the engine over, still no tell tale (pee stream) off the engine after running it while watching the temperature gauge. There's certainly pressure (movement of hot air) coming from the tell tale location, and I know it's clear enough for water to push out with the pump cleaning system pushing water into engine.....I'm not really sure what the cause could be at this moment. I used a temperature gun while the engine was running to see where the hottest parts of the engine are....and it was toward the top of where the rectifier is located. I thought about tracing everything back (whatever I need to remove); I actually bought gaskets for the entire engine to open up everything to see if there could be a clog in the system somewhere?? I think it's also worth noting, with the thermostat removed and the lower unit off, I ran the pump to push water straight into the water pump inline of the engine and water shot out of the hose on top that connects to the thermostat housing. <br><br>I'm currently scratching my head and hoping someone can provide some insight or solutions to get my motor peeing again. could it be at the rectifier, the vst? I haven't found a good diagram/illustration of where the engine water comes in and out of the motor. I did pull lines off the tell tale which led to a t fitting (one goes to the thermostat housing, the other to the front side of the motor. I noticed there are two lines that connect to the top and bottom of the front side of the engine (both male fittings where the water lines slip onto). Are these where the water delivers to the rest of the engine? <br><br>Another question I have, when you turn over the engine, does the drive shaft turn (which in turn turns the impeller in the housing) by turn over the engine or does it need to be in gear?? <br><br>I have a ton of pictures on my phone that I'm trying to add onto the forum to provide visuals. <br><br>Looking for some help on what could be the problem....appreciate any help anyone can provide!!
