I have a 2002 PCM 5.7L HO in a MB Sports Inboard. I've owned it since 2003 and every year, I drain the block to winterize. On the starboard side, the knock sensor is removed. For years, the original knock sensor appeared to have the tip missing but it threaded in and worked fine. Last winter I replaced it with the oem part and no issues this summer.
Yesterday, I removed it to drain the block and just a trickle of water came out. In time, it seemed to drain completely but I got a flashlight and mirror to see up inside the hole and it was blocked. My first thought was that part of the old sensor was still in place and had some debris fill in the gap to make it plug.
So I got a small punch out and went around the circumference of the hole and got most of it knocked out. What was left appears to be a hole, but slightly smaller in diameter. I didn't have a tap (I measured the threads on the new knock sensor as 14mm x 1.5 pitch) but assume I can clean up the threads and hopefully push the remaining material through.
My question is, Should that hole be uniform in diameter or is it designed to prevent the knock sensor from going in too far?
Thanks so much,
RickR90s
Thanks so much,
RickR90s
